Efficiency in large dynamic panel models with common factor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper deals with efficient estimation in exchangeable nonlinear dynamic panel models with common unobservable factor. The specification accounts for both micro- and macro-dynamics, induced by the lagged individual observation and the common stochastic factor, respectively. For large cross-sectional and time dimensions, and under a semiparametric identification condition, we derive the efficiency bound and introduce efficient estimators for both the micro- and macro-parameters. In particular, we show that the fixed effects estimator of the micro-parameter is not only consistent, but also asymptotically efficient.The results are illustrated with the stochastic migration model for credit risk analysis.
p248.pdf (662.47 Ko) Télécharger le fichier
inria-00386744 , version 1 (22-05-2009)
  • HAL Id : inria-00386744 , version 1
Patrick Gagliardini, Christian Gourieroux. Efficiency in large dynamic panel models with common factor. 41èmes Journées de Statistique, SFdS, Bordeaux, 2009, Bordeaux, France, France. ⟨inria-00386744⟩
74 Consultations
173 Téléchargements
