s'authentifier
version française rss feed
inria-00390423, version 1
Online adaptation of reference trajectories for the control of walking systems
Pierre-Brice Wieber () a1, Christine Chevallereau () 2
Robotics and Autonomous Systems 54, 7 (2006) 559-566
Résumé : A simple and widely used way to make a robotic system walk without falling is to make it track a reference tra jectory in one way or another, but the stability obtained this way may be limited and even small perturbations may lead to a fall. We propose here a series of heuristics to improve the stability that can be obtained from such a tracking control law, through an online adaptation of the choice of the reference tra jectory being tracked. Encouraging simulations are obtained in the end on a simple planar biped model.
  • Domaine : Informatique/Robotique
    Informatique/Automatique
  • inria-00390423, version 1
  • oai:hal.inria.fr:inria-00390423
  • Contributeur :
  • Soumis le : Mardi 2 Juin 2009, 10:19:59
  • Dernière modification le : Vendredi 12 Juin 2009, 15:26:00
tous les articles de la base du CCSd...
