inria-00390475, version 1
Kinematics estimation of straddled movements on high bar from a limited number of skin markers using a chain model
Mickael Begon
1Pierre-Brice Wieber
a, 2Maurice Raymond Yeadon 1
Journal of Biomechanics 41, 3 (2008) 581-586
Résumé : To reduce the effects of skin movement artefacts and apparent joint dislocations in the kinematics of whole body movement derived from marker locations, global optimisation procedures with a chain model have been developed. These procedures can also be used to reduce the number of markers when self-occlusions are hard to avoid. This paper assesses the kinematics precision of three marker sets: 16, 11 and 7 markers, for movements on high bar with straddled piked posture. A three-dimensional person-specific chain model was defined with 9 parameters and 12 degrees of freedom and an iterative procedure optimised the gymnast posture for each frame of the three marker sets. The time histories of joint angles obtained from the reduced marker sets were compared with those from the 16 marker set by means of a root mean square difference measure. Occlusions of medial markers fixed on the lower limb occurred when the legs were together and the pelvis markers disappeared primarily during the piked posture. Despite these occlusions, reconstruction was possible with 16, 11 and 7 markers. The time histories of joint angles were similar; the main differences were for the thigh mediolateral rotation and the knee flexion because the knee was close to full extension. When five markers were removed, the average angles difference was about 3. This difference increased to 9 for the seven marker set. It is concluded that kinematics of sports movement can be reconstructed using a chain model and a global optimisation procedure for a reduced number of markers.
- a – INRIA
- 1 : School of Sport and Exercise Sciences
- Loughborough University
- 2 : BIPOP (INRIA Grenoble Rhône-Alpes / LJK Laboratoire Jean Kuntzmann)
- INRIA – Laboratoire Jean Kuntzmann
- Domaine : Physique/Mécanique/Biomécanique
Sciences de l'ingénieur/Mécanique/Biomécanique
- inria-00390475, version 1
- http://hal.inria.fr/inria-00390475
- oai:hal.inria.fr:inria-00390475
- Contributeur : Pierre-Brice Wieber
- Soumis le : Mardi 2 Juin 2009, 11:27:00
- Dernière modification le : Mercredi 1 Juillet 2009, 17:00:24
Documents associés
Exporter
