inria-00390581, version 1
Prioritizing linear equality and inequality systems: application to local motion planning for redundant robots
Oussama Kanoun 1Florent Lamiraux
1Pierre-Brice Wieber
a, 2, 3Fumio Kanehiro 4Eiichi Yoshida
3Jean-Paul Laumond
1
IEEE International Conference on Robotics & Automation (2009) inconnu
Résumé : We present a novel method for prioritizing both linear equality and inequality systems and provide one algo- rithm for its resolution. This algorithm can be summarized as a sequence of optimal resolutions for each linear system following their priority order. We propose an optimality criterion that is adapted to linear inequality systems and characterize the result- ing optimal sets at every priority level. We have successfully applied our method to plan local motions for the humanoid robot HPR-2. We will demonstrate the validity of the method using an original scenario where linear inequality constraints are solved at lower priority than equality constraints.
- a – INRIA
- 1 : Laboratoire d'analyse et d'architecture des systèmes (LAAS)
- CNRS : UPR8001 – Université Paul Sabatier - Toulouse III – Institut National Polytechnique de Toulouse - INPT – Institut National des Sciences Appliquées de Toulouse
- 2 : BIPOP (INRIA Grenoble Rhône-Alpes / LJK Laboratoire Jean Kuntzmann)
- INRIA – Laboratoire Jean Kuntzmann
- 3 : Joint Japanese-French Robotics Laboratory (JRL)
- AIST – CNRS : UMR
- 4 : National Institute of Advanced Industrial Science and Technology (AIST)
- National Institute of Advanced Industrial Science and Technology
- Domaine : Informatique/Robotique
- inria-00390581, version 1
- http://hal.inria.fr/inria-00390581
- oai:hal.inria.fr:inria-00390581
- Contributeur : Pierre-Brice Wieber
- Soumis le : Mardi 2 Juin 2009, 14:25:50
- Dernière modification le : Mercredi 19 Janvier 2011, 16:48:33
Documents associés
Exporter
