s'authentifier
version française rss feed
inria-00390587, version 1
A Two-Steps Next-Best-View Algorithm for Autonomous 3D Object Modeling by a Humanoid Robot
Torea Foissotte 1, Olivier Stasse 1, Adrien Escande 1, Pierre-Brice Wieber () a12, Abderrahmane Kheddar 1
IEEE International Conference on Robotics & Automation (2009)
Résumé : A novel approach is presented which aims at building autonomously visual models of unknown objects, using a humanoid robot. Previous methods have been proposed for the specific problem of the next-best-view during the modeling and the recognition process. However our approach differs as it takes advantage of humanoid specificities in terms of embedded vision sensor and redundant motion capabilities. In a previous work, another approach to this specific problem was presented which relies on a derivable formulation of the visual evaluation in order to integrate it with our posture generation method. However to get rid of some limitations we propose a new method, formulated using two steps: (i) an optimization algorithm without derivatives is used to find a camera pose which maximizes the amount of unknown data visible, and (ii) a whole robot posture is generated by using a different optimization method where the computed camera pose is set as a constraint on the robot head.
  • Domaine : Informatique/Robotique
  • inria-00390587, version 1
  • oai:hal.inria.fr:inria-00390587
  • Contributeur :
  • Soumis le : Mardi 2 Juin 2009, 14:30:04
  • Dernière modification le : Vendredi 12 Juin 2009, 14:02:44
tous les articles de la base du CCSd...
