s'authentifier
version française rss feed
inria-00392256, version 1
Reformulation and Decomposition Approaches for Traffic Routing in Optical Networks
Benoit Vignac () 12, François Vanderbeck () 13, Brigitte Jaumard () a4
(2009)
Résumé : We consider a multi-layer network design model arising from a real-life telecommunication application where traffic routing decisions imply the installation of expensive nodal equipment. Customer requests come in the form of bandwidth reservations for a given origin destination pair. Bandwidth demands are expressed as a multiple of nominal granularities. Each request must be single-path routed. Grooming several requests on the same wavelength and multiplexing wavelengths in the same optical stream allow a more efficient use of network capacity. However, each addition or withdrawal of a request from a wavelength requires optical to electrical conversion and the use of cross-connect equipment with expensive ports of high densities. The objective is to minimize the number of ports of the cross-connect equipment. We deal with backbone optical networks, therefore with networks with a moderate number of nodes (14 to 20) but thousands of requests. Further difficulties arise from the symmetries in wavelength assignment and traffic loading. Traditional multi-commodity network flow approaches are not suited for this problem. Instead, four alternative models relying on Dantzig-Wolfe and/or Benders' decomposition are introduced and compared. The formulations are strengthened using symmetry breaking restrictions, variable domain reduction, zero-one discretization of integer variables, and cutting planes. The resulting dual bounds are compared to the values of primal solutions obtained through hierarchical optimization and rounding procedures. For realistic size instances, our best approaches provide solutions with optimality gap of approximately 5% on average in around two hours of computing time.
  • inria-00392256, version 1
  • oai:hal.inria.fr:inria-00392256
  • Contributeur :
  • Soumis le : Samedi 6 Juin 2009, 12:56:49
  • Dernière modification le : Jeudi 26 Mai 2011, 15:40:22
tous les articles de la base du CCSd...
