New Developments and Cosine Effect in the Viscous Shallow Water and Quasi-Geostrophic Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Multiscale Modeling and Simulation: A SIAM Interdisciplinary Journal Année : 2008
The viscous Shallow Water Equations and Quasi-Geostrophic Equations are considered in this paper. Some new terms, related to the Coriolis force, are revealed thanks to a rigorous asymptotic analysis. After providing well-posedness arguments for the new models, the authors perform some numerical computations that confirm the role played by the cosine effect in various physical configurations.
MMS_070545_Rev2.pdf (400.08 Ko) Télécharger le fichier
inria-00392886 , version 1 (09-06-2009)
Carine Lucas, Antoine Rousseau. New Developments and Cosine Effect in the Viscous Shallow Water and Quasi-Geostrophic Equations. Multiscale Modeling and Simulation: A SIAM Interdisciplinary Journal, 2008, 7 (2), pp.796-813. ⟨10.1137/070705453⟩. ⟨inria-00392886⟩
159 Consultations
231 Téléchargements
