A simple approach to nonlinear tensile stiffness for accurate cloth simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2009
Recent Particle System models have evolved toward accurate representation of elastic stiffness based on continuum mechanics, converging to formulations that make them quite analogous to fast Finite Element methods. These formulations usually involve the linearization of tensors that help their formulation in the context of linear elasticity. Toward our objective of simulating the nonlinear properties of cloth accurately, we show through this work that this linearization can indeed be suppressed and replaced by adapted strain-stress laws relating precisely the nonlinear behavior of the material. This leads to very streamlined computations that are particularly efficient for simulating the nonlinear anisotropic tensile elasticity of deformable surfaces. Through a simple and efficient implementation using the Particle System formalism, we demonstrate the efficiency of this method with examples related to garment simulation.
tensile.pdf (8.47 Mo) Télécharger le fichier
Format : Figure, Image
inria-00394466 , version 1 (02-12-2009)
Pascal Volino, Nadia Magnenat-Thalmann, François Faure. A simple approach to nonlinear tensile stiffness for accurate cloth simulation. ACM Transactions on Graphics, 2009, 28 (4), pp.Article No. 105. ⟨10.1145/1559755.1559762⟩. ⟨inria-00394466⟩
1298 Consultations
1854 Téléchargements
