Efficient, Physically Plausible Finite Elements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
This paper discusses FEM-based simulations of soft bodies in terms of speed and robustness. To be physically plausible, three fundamental laws must be respected: rotational invariance, Newton's law and Euler's law. We show that precomputed strain-displacement matrices generate nonphysical torques which can lead to visual artifacts. We then derive the fastest FEM-based method meeting our criteria of plausibility and robustness and discuss their limitations.
NPF05.pdf (2.56 Mo) Télécharger le fichier
efficient_plausible_FE.wmv (6.88 Mo) Télécharger le fichier
npf05-ERRATUM.pdf (27.09 Ko) Télécharger le fichier
Format : Figure, Image
inria-00394480 , version 1 (11-06-2009)
inria-00394480 , version 2 (19-02-2012)
  • HAL Id : inria-00394480 , version 2
Matthieu Nesme, Yohan Payan, François Faure. Efficient, Physically Plausible Finite Elements. Eurographics, Aug 2005, Dublin, Ireland. ⟨inria-00394480v2⟩
2865 Consultations
741 Téléchargements
