Trust protocol integrating services' semantics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In high dynamic environments such as Internet or pervasive computing, different unknown services are provided. When two services communicate, they share properties to negotiate a provided service. By introducing trust, services rely on the identity of the participants, to evaluate a trust level and adapt this provided service. However, it is not always possible to verify identity. In this paper, we propose a service-to-service trust protocol based on services' description. By exchanging their descriptions, services build trust in each other and adapt the quality of the provided service through policies.
UbiqNW2007.pdf (212.67 Ko) Télécharger le fichier
inria-00395103 , version 1 (14-06-2009)
  • HAL Id : inria-00395103 , version 1
Cédric Lévy-Bencheton, Frédéric Le Mouël. Trust protocol integrating services' semantics. Proceedings of the 4th Workshop for Ubiquitous Networking and Enablers to Context-Aware Services (Ubiq NW) in conjunction with the 4th International Symposium on Ubiquitous Computing Systems (UCS 2007), Nov 2007, Tokyo, Japan. ⟨inria-00395103⟩
98 Consultations
55 Téléchargements
