Combining Processor Virtualization and Component-Based Engineering in C for Heterogeneous Many-Core Platforms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Erven Rohou
Ali Erdem Özcan
  • Fonction : Auteur
  • PersonId : 839997
Embedded system design is driven by strong efficiency constraints in terms of performance, silicon area and power consumption, as well as pressure on the cost and time-to-market. As of today, this forms three tough problems: 1) many-core systems are becoming mainstream, however there is still no decent approach for distributing software applications on those platforms; 2) these systems still integrate heterogeneous processors for efficiency reasons, thus programming them requires complex compilation environments; 3) hardware resources are precious and low-level languages are still a must to exploit them subtly. These factors have negative impact on the programmability of many-core platforms and limit our ability to address the challenges of the next decade. This paper devises a new programming approach leveraging processor virtualization and component-based software engineering technologies to address these issues all together. It presents a programming model based on C for developing fine grain component-based applications, and a toolset that compiles them into a processor-independent bytecode representation that can be deployed on heterogeneous platforms. We also discuss the effectiveness of this approach and present some ideas that might have a key role in addressing the above challenges.
RR-6933.pdf (300.56 Ko) Télécharger le fichier
inria-00397823 , version 1 (23-06-2009)
  • HAL Id : inria-00397823 , version 1
Erven Rohou, Andrea Carlo Ornstein, Ali Erdem Özcan, Marco Cornero. Combining Processor Virtualization and Component-Based Engineering in C for Heterogeneous Many-Core Platforms. [Research Report] RR-6933, INRIA. 2009, pp.17. ⟨inria-00397823⟩
280 Consultations
214 Téléchargements
