Efficient and scalable merging algorithms for wireless traces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Analysis of wireless experimentation results is a complex task to achieve. As multiple probes are needed in order to get a global view of a wireless experimentation, the resulting packet traces may be very large. In this paper we propose an algorithm that realizes trace synchronization and merging in a scalable way. The algorithm generates a database that only stores the information marked as relevant for post-processing analysis by the experimenter. Initial performance results are promising.
RR-6969.pdf (419.07 Ko) Télécharger le fichier
inria-00397832 , version 1 (25-06-2009)
  • HAL Id : inria-00397832 , version 1
Bilel Ben Romdhanne, Diego Dujovne, Thierry Turletti, Walid Dabbous. Efficient and scalable merging algorithms for wireless traces. [Research Report] RR-6969, INRIA. 2009, pp.15. ⟨inria-00397832⟩
216 Consultations
236 Téléchargements
