Reconfigurable SCA Applications with the FraSCAti Platform - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
The Service Component Architecture (SCA) is a technology agnostic standard for developing and deploying distributed service-oriented applications. However, SCA does not define standard means for runtime manageability (including introspection and reconfiguration) of SOA applications and of their supporting environment. This paper presents the FraSCAti platform, which brings runtime management features to SCA, and discusses key principles in its design: the adoption of an extended SCA component model for the implementation of SOA applications and of the FraSCAti platform itself; the use of component-based interception techniques for dynamically weaving non-functional services such as transaction management with components. The paper presents micro-benchmarks that show that runtime manageability in the FraSCAti platform is achieved without hindering its performance relative to the de facto reference SCA implementation, Apache's Tuscany.
frascati.pdf (416.13 Ko) Télécharger le fichier
inria-00397856 , version 1 (23-06-2009)
  • HAL Id : inria-00397856 , version 1
Lionel Seinturier, Philippe Merle, Damien Fournier, Nicolas Dolet, Valerio Schiavoni, et al.. Reconfigurable SCA Applications with the FraSCAti Platform. 6th IEEE International Conference on Service Computing (SCC'09), IEEE, Sep 2009, Bangalore, India. pp.268-275. ⟨inria-00397856⟩
293 Consultations
602 Téléchargements
