N-way morphing for 2D Animation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Animation and Virtual Worlds Année : 2009
We present a novel approach to the creation of varied animations from a small set of simple 2D input shapes. Instead of providing a new 2D shape for each keyframe of an animation sequence, we instead interpolate between a few example shapes in a reduced pose-space. Similar approaches have been presented in the past, but were restricted in the types of input or range of deformations allowed. In order to address these limitations, we reformulate the problem as an N-way morphing process on 2D input bitmap or vector graphics. Our formulation includes an N-way mapping technique, an efficient, rigidity preserving non-linear blending function, improved extrapolation, and a novel scattered data interpolation technique to manage the reduced pose-space. The resulting animations are correlated to paths in the reduced pose-space, allowing users to intuitively and interactively control temporal behaviors with simple gestures. We demonstrate our techniques in several example animations.
main.pdf (1.2 Mo) Télécharger le fichier
Format : Figure, Image
inria-00400830 , version 1 (09-06-2011)
  • HAL Id : inria-00400830 , version 1
William Baxter, Pascal Barla, Ken-Ichi Anjyo. N-way morphing for 2D Animation. Computer Animation and Virtual Worlds, 2009, 20 (2). ⟨inria-00400830⟩
955 Consultations
3659 Téléchargements
