A Controllable, Fast and Stable Basis for Vortex Based Smoke Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
We introduce a novel method for describing and controlling a 3D smoke simulation. Using harmonic analysis and principal component analysis, we define an underlying description of the fluid flow that is compact and meaningful to non-expert users. The motion of the smoke can be modified with high level tools, such as animated current curves, attractors and tornadoes. Our simulation is controllable, interactive and stable for arbitrarily long periods of time. The simulations computational cost increases linearly in the number of motion samples and smoke particles. Our adaptive smoke particle representation conveniently incorporates the surface-like characteristics of real smoke.
smoke_sca06.pdf (5.26 Mo) Télécharger le fichier
smoke_sca06.ppt (2.16 Mo) Télécharger le fichier
smokefinalSCA.avi (33.34 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Vidéo
inria-00402106 , version 1 (20-05-2011)
  • HAL Id : inria-00402106 , version 1
Alexis Angelidis, Fabrice Neyret, Karan Singh, Derek Nowrouzezahrai. A Controllable, Fast and Stable Basis for Vortex Based Smoke Simulation. Symposium on Computer Animation (SCA 06), ACM-SIGGRAPH/EG, Sep 2006, Vienne, Austria. p. 25-32. ⟨inria-00402106⟩
410 Consultations
703 Téléchargements
