Effects of a Modulatory Feedback upon the BCM learning rule - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Thomas Girod
  • Fonction : Auteur
  • PersonId : 836949
Frédéric Alexandre
By applying a modulatory feedback upon the BCM learning rule, we show that it is possible to introduce a bias in the learning process, thus promoting a certain kind of selectivity on the feedforward path.
CNS_0259_0fde3a1b09972.pdf (65.87 Ko) Télécharger le fichier
inria-00402514 , version 1 (07-07-2009)
  • HAL Id : inria-00402514 , version 1
Thomas Girod, Frédéric Alexandre. Effects of a Modulatory Feedback upon the BCM learning rule. Computational Neuroscience, Jul 2009, Berlin, Germany. ⟨inria-00402514⟩
140 Consultations
253 Téléchargements
