Swirling-Sweepers: Constant Volume Modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Graphical Models Année : 2006
Swirling-sweepers is a new method formodeling shapes while preserving volume. The artist describes a deformation by dragging a point along a path. The method is independent of the geometric representation of the shape. It preserves volume and avoids self-intersections, both local and global. It is capable of unlimited stretching and the deformation can be constrained to affect only a part of the model. We argue that all of these properties are necessary for interactive modeling if the user is to have the impression that he or she is shaping a real material. Our method is the first to implement all five.
ACWK04.pdf (338.37 Ko) Télécharger le fichier
Format : Figure, Image
inria-00402557 , version 1 (20-03-2012)
  • HAL Id : inria-00402557 , version 1
Alexis Angelidis, Marie-Paule Cani, Geoff Wyvill, Scott King. Swirling-Sweepers: Constant Volume Modeling. Graphical Models, 2006, Special Issue: best of Pacific Graphics 2004., 68 (4), pp.324-332. ⟨inria-00402557⟩
1372 Consultations
489 Téléchargements
