Hierarchical study of Guyton Circulatory Model
This article presents an initial study of the Guyton Circulatory Model using BioRica. This model consists of 18 connected modules, each of which caracterise a separate physiological subsystem. We have focused the present analysis in the Renin- Angiotensin-Aldosterone System (RAAS). The use of BioRica allowed us to build an hierarchical model for this system by means of directly mapping modules to BioRica nodes. The results of each node were validated by comparison with published results.
jobim38.pdf (39.24 Ko)
Télécharger le fichier
JOBIM_ASSAR.pdf (258.11 Ko)
Format : Autre
