inria-00404171, version 1
Helly-type theorems for approximate covering
Julien Demouth
1Olivier Devillers
2Marc Glisse
3Xavier Goaoc
1
Discrete & Computational Geometry 42, 3 (2009) 379--398
Résumé : Let F ∪ {U } be a collection of convex sets in Rd such that F covers U . We prove that if the elements of F and U have comparable size then a small subset of F suffices to cover most of the volume of U ; we analyze how small this subset can be depending on the geometry of the elements of F , and show that smooth convex sets and axis parallel squares behave differently. We obtain similar results for surface-to-surface visibility amongst balls in 3 dimensions for a notion of volume related to form factor. For each of these situations, we give an algorithm that takes F and U as input and computes in time O (|F | ∗ |Hϵ |) either a point in U not covered by or a subset ϵ covering U up to a measure ϵ, with ϵ meeting our combinatorial bounds.
- 1 : VEGAS (INRIA Lorraine - LORIA)
- INRIA – CNRS : UMR7503 – Université Henri Poincaré - Nancy I – Université Nancy II – Institut National Polytechnique de Lorraine (INPL)
- 2 : GEOMETRICA (INRIA Sophia Antipolis / INRIA Saclay - Ile de France)
- INRIA
- 3 : Grenoble Images Parole Signal Automatique (GIPSA-lab)
- CNRS : UMR5216 – Université Joseph Fourier - Grenoble I – Université Pierre Mendès-France - Grenoble II – Université Stendhal - Grenoble III – Institut Polytechnique de Grenoble - Grenoble Institute of Technology
- Domaine : Informatique/Géométrie algorithmique
- inria-00404171, version 1
- http://hal.inria.fr/inria-00404171
- oai:hal.inria.fr:inria-00404171
- Contributeur : Olivier Devillers
- Soumis le : Mercredi 15 Juillet 2009, 15:58:31
- Dernière modification le : Jeudi 12 Novembre 2009, 11:42:35
Documents associés
Exporter
