Attributed Graph Matching using Local Descriptions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In the pattern recognition context, objects can be represented as graphs with attributed nodes and edges involving their relations. Consequently, matching attributed graphs plays an important role in objects recognition. In this paper, a node signatures extraction is combined with an optimal assignment method for matching attributed graphs. In particular, we show how local descriptions are used to define a node-to-node cost in an assignment problem using the Hungarian method. Moreover, we propose a distance formula to compute the distance between attributed graphs. The experiments demonstrate that the newly presented algorithm is well-suited to pattern recognition applications. Compared with well-known methods, our algorithm gives good results for retrieving images.
paper163.pdf (335.24 Ko) Télécharger le fichier
inria-00404340 , version 1 (16-07-2009)
  • HAL Id : inria-00404340 , version 1
Salim Jouili, Salvatore Tabbone. Attributed Graph Matching using Local Descriptions. Advanced Concepts for Intelligent Vision Systems - Acivs 2009, SEE, Sep 2009, Bordeaux, France. ⟨inria-00404340⟩
435 Consultations
1369 Téléchargements
