s'authentifier
version française rss feed
inria-00409744, version 2
Design and Evaluation of 3D Positioning Techniques for Multi-touch Displays
Anthony Martinet () a12, Gery Casiez (Auteur à contacter de préférence) a12, Laurent Grisoni () 12
N° RR-7015 (2009)
Résumé : Multi-touch displays represent a promising technology for the display and manipulation of 3D data. To fully exploit their capabilities, appropriate interaction techniques must be designed. In this paper, we explore the design of free 3D positioning techniques for multi-touch displays to exploit the additional degrees of freedom provided by this technology. We present a first interaction technique to extend the standard four viewports technique found in commercial CAD applications and a second technique designed to allow free 3D positioning with a single view of the scene. The two techniques were then evaluated in a controlled experiment. Results show no statistical difference for the positioning time but a clear preference for the Z-technique.
  • Domaine : Informatique/Interface homme-machine
  • Mots-clés : Multi-touch displays – 3D positioning task – direct manipulation
  • Référence interne : RR-7015
  • Versions disponibles :  v1 (15-08-2009) v2 (31-08-2009)
  • inria-00409744, version 2
  • oai:hal.inria.fr:inria-00409744
  • Contributeur :
  • Soumis le : Lundi 31 Août 2009, 14:56:52
  • Dernière modification le : Lundi 31 Août 2009, 15:05:15
tous les articles de la base du CCSd...
