inria-00410767, version 1
Searching with quantization: approximate nearest neighbor search using short codes and distance estimators
Hervé Jégou
1Matthijs Douze
a, 1Cordelia Schmid
a, 1
N° RR-7020 (2009)
Résumé : We propose an approximate nearest neighbor search method based on quantization. It uses, in particular, product quantizer to produce short codes and corresponding distance estimators approximating the Euclidean distance between the orginal vectors. The method is advantageously used in an asymmetric manner, by computing the distance between a vector and code, unlike competing techniques such as spectral hashing that only compare codes. Our approach approximates the Euclidean distance based on memory efficient codes and, thus, permits efficient nearest neighbor search. Experiments performed on SIFT and GIST image descriptors show excellent search accuracy. The method is shown to outperform two state-of-the-art approaches of the literature. Timings measured when searching a vector set of 2 billion vectors are shown to be excellent given the high accuracy of the method.
- a – INRIA
- 1 : LEAR (INRIA Grenoble Rhône-Alpes / LJK Laboratoire Jean Kuntzmann)
- CNRS : FR71 – CNRS : UMR5527 – INRIA – Laboratoire Jean Kuntzmann – Université Joseph Fourier - Grenoble I – Institut National Polytechnique de Grenoble (INPG)
- Domaine : Informatique/Recherche d'information
- Référence interne : RR-7020
- inria-00410767, version 1
- http://hal.inria.fr/inria-00410767
- oai:hal.inria.fr:inria-00410767
- Contributeur : Hervé Jégou
- Soumis le : Lundi 24 Août 2009, 12:57:37
- Dernière modification le : Mardi 13 Mars 2012, 11:40:50
Documents associés
Exporter
