Structure and Implementation of a SIMO Multi-Standard Multichannel SDR Receiver - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This article presents the structure of a multiantenna multi-channel and multi-standard receiver based on Software Defined Radio (SDR) concept. At this time our work is focused on 802.11g and 802.11b signals cohabiting in a 40 MHz frequency bandwidth around the 2.4 GHz RF carrier frequency. Using classical Single Input Multiple Output (SIMO) processing, these incoming signals are combined to increase transmission performances and to mitigate fading effect. Simulated and measured results of our structure are given and a description of the real proposed architecture is detailed.
rws08fin.pdf (223.55 Ko) Télécharger le fichier
inria-00412054 , version 1 (27-11-2009)
  • HAL Id : inria-00412054 , version 1
Pierre-Francois Morlat, Antonio Luna, Xavier Gallon, Guillaume Villemaud, Jean-Marie Gorce. Structure and Implementation of a SIMO Multi-Standard Multichannel SDR Receiver. IEEE Radio and Wireless Symposium, Jan 2008, Orlando, United States. ⟨inria-00412054⟩
127 Consultations
221 Téléchargements
