Wlan Preamble Detection Methods in a Multi-Antenna, Multi-Standards Software Defined Radio Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This paper presents a comparison of different detection methods which could be used to sense a frequency band in order to select a particular channel and a particular communication standard in a wideband melted signal. Here we focus on a generic WLAN receiver based on SDR principles, capable of sampling several overlapping channels to demodulate simultaneously concurrent users possibly using different waveforms.
eucap07_alaus.pdf (126.16 Ko) Télécharger le fichier
inria-00412056 , version 1 (27-11-2009)
  • HAL Id : inria-00412056 , version 1
Laurent Alaus, Guillaume Villemaud, Pierre-Francois Morlat, Jean-Marie Gorce. Wlan Preamble Detection Methods in a Multi-Antenna, Multi-Standards Software Defined Radio Architecture. European Conference on Antennas and Propagation, Nov 2007, Edinburgh, United Kingdom. ⟨inria-00412056⟩
79 Consultations
687 Téléchargements
