inria-00412600, version 1
Evaluating the cylindricity of a nominally cylindrical point set
Olivier Devillers
1Franco Preparata a, 2
ACM-SIAM Sympos. Discrete Algorithms (2000)
Résumé : The minimum zone cylinder of a set of points in three dimensions is the cylindric crown defined by a pair of coaxial cylinders with minimal radial separation (width). In the context of tolerancing metrology, the set of points is nominally cylindrical, i.e., the points are known to lie in close proximity of a known reference cylinder. Using approximations which are valid only in the neighborhood of the reference cylinder, we can get a very good approximation of the minimum zone cylinder. The process provides successive approximations, and each iteration involves the solution of a linear programming problem in six dimensions. The error between the approximation and the optimal solution converges very rapidly (typically in three iterations in practice) down to a limit error of (8 omega^2)/R ( where omega is the width and R is the external radius of the zone cylinder).
- a – John Brown University
- 1 : PRISME (INRIA Sophia Antipolis)
- INRIA
- 2 : Department of Computer Science (Brown University)
- Brown University
- Domaine : Informatique/Géométrie algorithmique
- inria-00412600, version 1
- http://hal.inria.fr/inria-00412600
- oai:hal.inria.fr:inria-00412600
- Contributeur : Olivier Devillers
- Soumis le : Mercredi 2 Septembre 2009, 11:34:00
- Dernière modification le : Mercredi 2 Septembre 2009, 11:35:26
Documents associés
Exporter
