s'authentifier
version française rss feed
inria-00413144, version 1
Isotropic Surface Remeshing
Pierre Alliez () 1, Éric Colin De Verdière 2, Olivier Devillers () 1, Martin Isenburg 3
International Conference on Shape Modeling and applications, (2003)
Résumé : This paper proposes a new method for isotropic remeshing of tri- angulated surface meshes. Given a triangulated surface mesh to be resampled and a user-specified density function defined over it, we first distribute the desired number of samples by generalizing error diffusion, commonly used in image halftoning, to work directly on mesh triangles and feature edges. We then use the resulting sam- pling as an initial configuration for building a weighted centroidal Voronoi tessellation in a conformal parameter space, where the specified density function is used for weighting. We finally create the mesh by lifting the corresponding constrained Delaunay trian- gulation from parameter space. A precise control over the sampling is obtained through a flexible design of the density function, the latter being possibly low-pass filtered to obtain a smoother grada- tion. We demonstrate the versatility of our approach through vari- ous remeshing examples.
  • Domaine : Informatique/Géométrie algorithmique
  • inria-00413144, version 1
  • oai:hal.inria.fr:inria-00413144
  • Contributeur :
  • Soumis le : Jeudi 3 Septembre 2009, 12:00:03
  • Dernière modification le : Jeudi 3 Septembre 2009, 14:09:49
tous les articles de la base du CCSd...
