s'authentifier
version française rss feed
inria-00413168, version 1
Queries on Voronoi Diagrams of Moving Points
Olivier Devillers () 1, Mordecai Golin 2, Klara Kedem a1, Stefan Schirra 3
Computational Geometry 6 (1996) 315-327
Résumé : Suppose we are given n moving postmen described by their motion equations pi(t) = si + vi t, i=1, ... , n, where si belongs to R2 is the position of the i'th postman at time t=0, and vi in R2 is his velocity. The problem we address is how to preprocess the postmen data so as to be able to efficiently answer two types of nearest-neighbor queries. The first one asks ``who is the nearest postman at time tq to a dog located at point sq. In the second type a query dog is located at point sq at time tq, its speed is vq>|vi| (for all i=1, ... , n), and we want to know which postman the dog can catch first. The first type of query is relatively simple to address, the second type at first seems much more complicated. We show that the problems are very closely related, with efficient solutions to the first type of query leading to efficient solutions to the second. We then present two solutions to these problems, with tradeoff between preprocessing time and query time. Both solutions use deterministic data structures.
  • Domaine : Informatique/Géométrie algorithmique
  • inria-00413168, version 1
  • oai:hal.inria.fr:inria-00413168
  • Contributeur :
  • Soumis le : Jeudi 3 Septembre 2009, 13:34:00
  • Dernière modification le : Jeudi 3 Septembre 2009, 14:16:41
tous les articles de la base du CCSd...
