s'authentifier
version française rss feed
inria-00413179, version 1
Checking the convexity of polytopes and the planarity of subdivisions.
Olivier Devillers () 1, Giuseppe Liotta 2, Franco Preparata a3, Roberto Tamassia 3
Computational Geometry 11 (1998) 187-208
Résumé : This paper considers the problem of verifying the correctness of geometric structures. In particular, we design simple optimal checkers for convex polytopes in two and higher dimensions, and for various types of planar subdivisions, such as triangulations, Delaunay triangulations, and convex subdivisions. Their performance is analyzed also in terms of the algorithmic degree, which characterizes the arithmetic precision required.
  • Domaine : Informatique/Géométrie algorithmique
  • inria-00413179, version 1
  • oai:hal.inria.fr:inria-00413179
  • Contributeur :
  • Soumis le : Jeudi 3 Septembre 2009, 13:56:46
  • Dernière modification le : Jeudi 3 Septembre 2009, 14:18:35
tous les articles de la base du CCSd...
