s'authentifier
version française rss feed
inria-00413181, version 1
Convex Tours of Bounded Curvature.
Jean-Daniel Boissonnat () 1, Jurek Czyzowicz a2, Olivier Devillers () 1, Jean-Marc Robert 3, Mariette Yvinec () 1
Computational Geometry 13 (1999) 149-160
Résumé : We consider the motion planning problem for a point constrained to move along a smooth closed convex path of bounded curvature. The workspace of the moving point is bounded by a convex polygon with m vertices, containing an obstacle in a form of a simple polygon with n vertices. We present an O(m+n) time algorithm finding the path, going around the obstacle, whose curvature is the smallest possible.
  • Domaine : Informatique/Géométrie algorithmique
  • inria-00413181, version 1
  • oai:hal.inria.fr:inria-00413181
  • Contributeur :
  • Soumis le : Jeudi 3 Septembre 2009, 14:06:11
  • Dernière modification le : Jeudi 3 Septembre 2009, 14:12:33
tous les articles de la base du CCSd...
