s'authentifier
version française rss feed
inria-00413229, version 1
A Locally Optimal Triangulation of the Hyperbolic Paraboloid
Pascal Desnogues 1, Olivier Devillers () 1
Canadian Conference on Computational Geometry (1995) 49-54
Résumé : Given a set S of data points in R2 and corresponding data val ues for a specific non-convex surface, the unit hyperbolic paraboloid, we consider the problem of finding a locally optimal triangulation of S for the linear approximation of this surface. The chosen optimality criterion will be the L2 norm: it means that we will try to find directly a triangulation that minimizes the L2 error made when approximating locally the surface with triangles.
  • Domaine : Informatique/Géométrie algorithmique
  • inria-00413229, version 1
  • oai:hal.inria.fr:inria-00413229
  • Contributeur :
  • Soumis le : Jeudi 3 Septembre 2009, 15:18:03
  • Dernière modification le : Jeudi 3 Septembre 2009, 15:57:12
tous les articles de la base du CCSd...
