inria-00413351, version 1
Fast Delaunay Triangulation for Converging Point Relocation Sequences
Pedro Machado Manhaes De Castro
1Olivier Devillers
1
European Workshop on Computational Geometry (2009)
Résumé : This paper considers the problem of updating efficiently a Delaunay triangulation when vertices are moving under small perturbations. Its main contribution is a set of algorithms based on the concept of vertex tolerance. Experiments show that it is able to outperform the naive rebuilding algorithm in certain conditions. For instance, when points, in two dimensions, are relocated by Lloyd's iterations, our algorithm performs several times faster than rebuilding.
- Domaine : Informatique/Géométrie algorithmique
- inria-00413351, version 1
- http://hal.inria.fr/inria-00413351
- oai:hal.inria.fr:inria-00413351
- Contributeur : Pedro Machado Manhaes De Castro
- Soumis le : Jeudi 3 Septembre 2009, 18:16:00
- Dernière modification le : Vendredi 6 Novembre 2009, 10:51:48
Documents associés
Exporter
