Enabling Context-Aware Web Services: A Middleware Approach for Ubiquitous Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2010
In ubiquitous environments, mobile applications should sense and react to environmental changes to provide a better user experience. In order to deal with these concerns, Service-Oriented Architectures (SOA) provide a solution allowing applications to interact with the services available in their surroundings. In particular, context-aware Web Services can adapt their behavior considering the user context. However, the limited resources of mobile devices restrict the adaptation degree. Furthermore, the diverse nature of context information makes difficult its retrieval, processing and distribution. To tackle these challenges, we present the CAPPUCINO platform for executing context-aware Web Services in ubiquitous environments. In particular, in this chapter we focus on the middleware part that is built as an autonomic control loop that deals with dynamic adaptation. In this autonomic loop we use FraSCAti, an implementation of the Service Component Architecture (SCA) specification, as the execution kernel for Web Services. The context distribution is achieved with SPACES, a flexible solution based on REST (REpresentational State Transfer ) principles and benefiting from the COSMOS (COntext entitieS coMpositiOn and Sharing ) context manage- ment framework. The application of our platform is illustrated with a mobile commerce application scenario that combines context-aware Web Services and social networks.
chapitre.pdf (956.23 Ko) Télécharger le fichier
inria-00414070 , version 1 (07-09-2009)
  • HAL Id : inria-00414070 , version 1
Daniel Romero, Romain Rouvoy, Lionel Seinturier, Sophie Chabridon, Denis Conan, et al.. Enabling Context-Aware Web Services: A Middleware Approach for Ubiquitous Environments. Michael Sheng and Jian Yu and Schahram Dustdar. Enabling Context-Aware Web Services: Methods, Architectures, and Technologies, Chapman and Hall/CRC, pp.113-135, 2010, 9781439809853. ⟨inria-00414070⟩
454 Consultations
654 Téléchargements
