Software Architecture and Dependability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Dependable systems are characterized by a number of attributes including: reliability, availability, safety and security. For some attributes (namely for reliability, availability, safety), there exist probability- based theoretic foundations, enabling the application of dependability analysis techniques. The goal of dependability analysis is to forecast the values of dependability attributes, based on certain properties (e.g. failure rate, MTBF, etc.) that characterize the system's constituent elements. Nowadays, architects, designers and developers build systems based on an architecture-driven approach. They specify the system's software architecture using Architecture Description Languages or other standard modeling notations like UML. Given the previous, we examine what we need to specify at the architectural level to enable the automated generation of models for dependability analysis. In this paper, we further present a prototype implementation of the proposed approach, which relies on UML specifications of dependable systems' software architectures. Moreover, we exemplify our approach using a case study system.
IssarnyZ03.pdf (327.49 Ko) Télécharger le fichier
inria-00414798 , version 1 (10-09-2009)
  • HAL Id : inria-00414798 , version 1
Valérie Issarny, Apostolos Zarras. Software Architecture and Dependability. Third International School on Formal Methods for the Design of Computer, Communication and Software Systems: Software Architectures : SFM 2003, 2003, Bertinoro, Italy. pp.259-286. ⟨inria-00414798⟩
Collections
INRIA INRIA2
120 Consultations
205 Téléchargements
