QoS-aware dynamic service composition in ambient intelligence environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Due to the large success of wireless networks and handheld devices, the ambient intelligence (AmI) paradigm is becoming a reality. One of the most challenging objectives to achieve in AmI environments is to enable a user to perform a task by composing on the fly networked services available at a specific time and place. Towards this goal, we propose a solution based on semantic Web services, and we show how service capabilities described as conversations can be integrated to perform a user task that is also described as a conversation, further meeting the QoS requirements of the user task. Experimental results show that the runtime overhead of our algorithm is reasonable, and further, that QoS-awareness improves its performance.
MokhtarLGI05.pdf (134.44 Ko) Télécharger le fichier
inria-00414943 , version 1 (10-09-2009)
  • HAL Id : inria-00414943 , version 1
Sonia Ben Mokhtar, Jinshan Liu, Nikolaos Georgantas, Valérie Issarny. QoS-aware dynamic service composition in ambient intelligence environments. 20th IEEE/ACM International Conference on Automated Software Engineering : ASE 2005, 2005, Long Beach, California, United States. pp.317-320. ⟨inria-00414943⟩
110 Consultations
425 Téléchargements
