Analyzing the Performance of Memory Management in RTSJ
The memory models used in the Real-Time Specification for Java (RTSJ) can incur high amounts of overhead; It is possible to reduce this overhead by taking advantages of hardware features. This paper provides an indepth analytical investigation of the overhead of write barriers in RTSJ VMs, and describes and analyzes some solutions to reduce the overhead of write barriers.
Informatique ubiquitaire
