A Security Supervision System for Hybrid Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2008
The traditional way of protecting networks and applications with e.g., firewalls and encryption, is no longer sufficient to protect effectively emerging hybrid wired-cum-wireless networks including ad hoc networks. Intrusion detection mechanisms should be coupled with preventive measures so as to identify unauthorised abuses. To this end, we propose a novel Hybrid Distributed Security Operation Center (HDSOC) which collects logs that are generated by any application/service, layer of the protocol stack or resource (e.g., router), providing a global view of the supervised system based on which complex and distributed intrusions can be detected. Our HDSOC further (i) distributes its capabilities and (ii) provides extensive coordination capabilities for guarantying that both the networks and the HDSOC components do not constitute isolated entities largely unaware of each others.
SailhanBI08.pdf (527.4 Ko) Télécharger le fichier
inria-00415144 , version 1 (10-09-2009)
  • HAL Id : inria-00415144 , version 1
Françoise Sailhan, Julien Bourgeois, Valérie Issarny. A Security Supervision System for Hybrid Networks. R. Lee. Software Engineering, Artificial Intelligence, Networking and Parallel/Distributed Computing, Springer, pp.137-149, 2008. ⟨inria-00415144⟩
133 Consultations
164 Téléchargements
