Automatic Synthesis of Behavior Protocols for Composable Web-Services - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Web-services are broadly considered as an effective means to achieve interoperability between heterogeneous parties of a business process and offer an open platform for developing new composite web-services out of existing ones. In the literature many approaches have been proposed with the aim to automatically compose web-services. All of them assume that, along with the webservice signature, some information is provided about how clients interacting with the web-service should behave when invoking it. We call this piece of information the web-service behavior protocol. Unfortunately, in the practice this assumption turns out to be unfounded. To address this need, in this paper we propose a method to automatically derive from the web-service signature an automaton modeling its behavior protocol. The method, called StrawBerry, combines synthesis and testing techniques. In particular, synthesis is based on data type analysis. The conformance between the synthesized automaton and the implementation of the corresponding web-service is checked by means of testing. The application of StrawBerry to the Amazon E-Commerce Service shows that it is practical and realistic.
Mots clés
esec107-bertolino.pdf (414.37 Ko) Télécharger le fichier
inria-00415421 , version 1 (11-09-2009)
Antonia Bertolino, Paola Inverardi, Pelliccione Patrizio, Tivoli Massimo. Automatic Synthesis of Behavior Protocols for Composable Web-Services. The 7th joint meeting of the European Software Engineering Conference (ESEC) and the ACM SIGSOFT Symposium on the Foundations of Software Engineering (FSE) – ESEC/FSE09, Aug 2009, Amsterdam, European Union. pp.141-150, ⟨10.1145/1595696.1595719⟩. ⟨inria-00415421⟩
Collections
CONNECT
78 Consultations
477 Téléchargements
