Curve/surface intersection problem by means of matrix representations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Laurent Busé
Bernard Mourrain
In this paper, we introduce matrix representations of algebraic curves and surfaces for Computer Aided Geometric Design (CAGD). The idea of using matrix representations in CAGD is quite old. The novelty of our contribution is to enable non square matrices, extension which is motivated by recent research in this topic. We show how to manipulate these representations by proposing a dedicated algorithm to address the curve/surface intersection problem by means of numerical linear algebra techniques.
snc2009.pdf (201.11 Ko) Télécharger le fichier
inria-00418403 , version 1 (18-09-2009)
Thang Luu Ba, Laurent Busé, Bernard Mourrain. Curve/surface intersection problem by means of matrix representations. SNC, Aug 2009, Kyoto, Japan. pp.71-78, ⟨10.1145/1577190.1577205⟩. ⟨inria-00418403⟩
274 Consultations
764 Téléchargements
