Adjectives in TreeLex - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The paper presents an ongoing project on automatic extraction of subcategorization frames of French adjectives. The extraction method is guided by syntactic corpus annotations and heuristic rules. In particular, we use general linguistic knowledge to eliminate impersonal, comparative and certain adverbial constructions from the list of subcategorisation patterns.
Linguistique
adj_iis_final_all.pdf (104.36 Ko) Télécharger le fichier
inria-00420990 , version 1 (30-09-2009)
  • HAL Id : inria-00420990 , version 1
Anna Kupść. Adjectives in TreeLex. Inteligent Information Systems, Jun 2008, Zakopane, Poland. ⟨inria-00420990⟩
84 Consultations
110 Téléchargements
