Object extraction using a stochastic birth-and-death dynamics in continuum - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Imaging and Vision Année : 2009
Xavier Descombes
Robert Minlos
  • Fonction : Auteur
  • PersonId : 838446
Elena Zhizhina
  • Fonction : Auteur
  • PersonId : 838447
We define a new birth and death dynamics dealing with configurations of disks in the plane. We prove the convergence of the continuous process and propose a discrete scheme converging to the continuous case. This framework is developed to address image processing problems consisting in detecting a configuration of objects from a digital image. The derived algorithm is applied for tree crown extraction and bird detection from aerial images. The performance of this approach is shown on real data.
Descombes.pdf (13.54 Mo) Télécharger le fichier
inria-00422411 , version 1 (06-10-2009)
  • HAL Id : inria-00422411 , version 1
Xavier Descombes, Robert Minlos, Elena Zhizhina. Object extraction using a stochastic birth-and-death dynamics in continuum. Journal of Mathematical Imaging and Vision, 2009. ⟨inria-00422411⟩
117 Consultations
304 Téléchargements
