Local Statistic Based Region Segmentation with Automatic Scale Selection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Jérome Piovano
  • Fonction : Auteur
  • PersonId : 863864
Théodore Papadopoulo
Recently, new segmentation models based on local information have emerged. They combine local statistics of the regions along the contour (inside and outside) to drive the segmentation procedure. Since they are based on local decisions, these models are more robust to local variations of the regions of interest (contrast, noise, blur, . . . ). They nonetheless also introduce some new difficulties which are inherent to the fact of basing a global property (the segmentation) on pure local decisions. This papers explores some of those difficulties and proposes some possible corrections. Results on both 2D and 3D data are compared to those obtained without these corrections.
piovano-papadopoulo_3A08.pdf (7.64 Mo) Télécharger le fichier
inria-00423331 , version 1 (09-10-2009)
Jérome Piovano, Théodore Papadopoulo. Local Statistic Based Region Segmentation with Automatic Scale Selection. European Conference on Computer Vision 2008, Oct 2008, Marseille, France. pp.486--499, ⟨10.1007/978-3-540-88688-4_36⟩. ⟨inria-00423331⟩
307 Consultations
176 Téléchargements
