Detection of Multiple Pathways in the Spinal Cord White Matter Using Q-Ball Imaging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
High angular resolution MRI such as q-ball imaging (QBI) allows to recover complex white matter architecture. We applied this technique to an ex vivo spinal cord of one cat using a 3T scanner, 100 directions and b-values varying from 1000 to 3000 s/mm2. As a result, QBI can retrieve crossing fibre information, where the diffusion tensor imaging approach is constrained to a single diffusion direction. To our knowledge, this is the first study demonstrating the benefits of QBI in observing longitudinal, commissural and dorso-ventral fibres in the spinal cord. It is a first step towards in vivo characterization of the healthy and injured spinal cord using high angular resolution diffusion imaging (HARDI) and QBI.
Detection.pdf (408.9 Ko) Télécharger le fichier
inria-00423368 , version 1 (19-11-2009)
Julien Cohen-Adad, Maxime Descoteaux, S. Rossignol, R. D. Hoge, Rachid Deriche, et al.. Detection of Multiple Pathways in the Spinal Cord White Matter Using Q-Ball Imaging. Biomedical Imaging: From Nano to Macro, 2008. ISBI 2008. 5th IEEE International Symposium on, May 2008, Paris, France. pp.696--699, ⟨10.1109/ISBI.2008.4541091⟩. ⟨inria-00423368⟩
279 Consultations
183 Téléchargements
