Improving Formatting Documents by Coupling Formatting Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Fateh Boulmaiz
Cécile Roisin
  • Fonction : Auteur
  • PersonId : 946792
In this paper, we present a framework for coupling an existing formatting system such as SMIL or Madeus with a formatting control system called XEF. This framework allows the coupling process to be performed at two levels: 1) the language level, which is concerned with how to link the control features of XEF and the elements of an existing formatting system, and 2) the formatter level, which deals with the creation of a new formatter by formatter composition. The overall objective is to provide more powerful and flexible formatting services to cover new needs such as adaptive and/or generated presentations.
doceng03.pdf (206.53 Ko) Télécharger le fichier
inria-00423395 , version 1 (09-10-2009)
Fateh Boulmaiz, Cécile Roisin, Frédéric Bès. Improving Formatting Documents by Coupling Formatting Systems. Proceedings of the 2003 ACM Symposium on Document Engineering, DocEng2003, Nov 2003, Grenoble, France. pp.92-94, ⟨10.1145/958220.958237⟩. ⟨inria-00423395⟩
Collections
INRIA INRIA2
76 Consultations
268 Téléchargements
