Non-smooth contact dynamics approach of cohesive materials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Philosophical Transactions of the Royal Society of London. Series A, Mathematical and Physical Sciences (1934–1990) Année : 2001
The main features of the non-smooth contact dynamics (NSCD) method—the dynamical equation, the Signorini relation as a non-smooth modelling of unilateral contact, and the frictional Coulomb's law, treated with fully implicit algorithms— are briefly presented in this paper. By mere changes of variables, it appears that a large class of interface problems, including cohesive interface problems, may be solved using Signorini, Coulomb and standard NSCD algorithms. Emphasis is put on contact between deformable bodies. Examples illustrating numerical simulation are given for fibre-reinforced materials and for buildings made of blocks.
JAMHaL.pdf (770.65 Ko) Télécharger le fichier
inria-00423556 , version 1 (03-05-2016)
Michel Jean, Vincent Acary, Yann Monerie. Non-smooth contact dynamics approach of cohesive materials. Philosophical Transactions of the Royal Society of London. Series A, Mathematical and Physical Sciences (1934–1990), 2001, 359 (1789), pp.2497-2518. ⟨10.1098/rsta.2001.0906⟩. ⟨inria-00423556⟩
349 Consultations
362 Téléchargements
