inria-00423955, version 1
The nonsmooth dynamical systems approach for the analog simulation of switched circuits within the Siconos framework
Vincent Acary
a, 1Olivier Bonnefon a, 1Bernard Brogliato
a, 1
N° RR-7061 (2009)
Résumé : The numerical integration of switching circuits is known to be a tough issue when the number of switches is high, or when sliding modes exist. Then classical analog simulators may behave poorly, or even fail. In this paper it is shown on two examples that the nonsmooth dynamical systems (NSDS) approach, which is made of 1) a specific modelling of the piecewise- linear electronic devices (ideal diodes, Zener diodes, transistors), 2) the Moreau's time-stepping scheme, and 3) specific iterative one-step solvers, supersedes simulators of the SPICE family and hybrid simulators. An academic example constructed in [Maffezzoni et al, IEEE Trans. on CADICS, Vol 25, No 11, November 2006], so that the Newton-Raphson scheme does not converge, and the buck converter, are used to make extensive comparisons between the NSDS method and other methods of the SPICE family and a hybrid-like method. The NSDS method, implemented in the Siconos platform developed at INRIA, proves to be on these two examples much faster and more robust with respect to the models parameters variations.
- a – INRIA
- 1 : BIPOP (INRIA Grenoble Rhône-Alpes / LJK Laboratoire Jean Kuntzmann)
- INRIA – Laboratoire Jean Kuntzmann
- Domaine : Informatique/Modélisation et simulation
- Mots-clés : Switching circuits – complementarity problems – backward Euler algorithm – power converters – complementarity dynamical systems – analog simulation – multivalued systems – unilat- eral state constraints.
- Référence interne : RR-7061
- inria-00423955, version 1
- http://hal.inria.fr/inria-00423955
- oai:hal.inria.fr:inria-00423955
- Contributeur : Vincent Acary
- Soumis le : Mardi 13 Octobre 2009, 14:34:34
- Dernière modification le : Vendredi 23 Octobre 2009, 17:20:11
Documents associés
Exporter
