A comparison between hardware accelerators for the modified Tate pairing over $\mathbb{F}_{2^m}$ and $\mathbb{F}_{3^m}$ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this article we propose a study of the modified Tate pairing in characteristics two and three. Starting from the $\eta_T$ pairing introduced by Barreto {\em et al.}, we detail various algorithmic improvements in the case of characteristic two. As far as characteristic three is concerned, we refer to the survey by Beuchat {\em et al.}. We then show how to get back to the modified Tate pairing at almost no extra cost. Finally, we explore the trade-offs involved in the hardware implementation of this pairing for both characteristics two and three. From our experiments, characteristic three appears to have a slight advantage over characteristic two.
pairing2008_rr.pdf (256.68 Ko) Télécharger le fichier
inria-00423977 , version 1 (13-10-2009)
Jean-Luc Beuchat, Nicolas Brisebarre, Jérémie Detrey, Eiji Okamoto, Francisco Rodríguez-Henríquez. A comparison between hardware accelerators for the modified Tate pairing over $\mathbb{F}_{2^m}$ and $\mathbb{F}_{3^m}$. Second International Conference on Pairing-Based Cryptography – Pairing 2008, Sep 2008, Egham, United Kingdom. pp.297-315, ⟨10.1007/978-3-540-85538-5_20⟩. ⟨inria-00423977⟩
184 Consultations
196 Téléchargements
