Toward a multiple impact law: the 3-ball chain example - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
The aim of this work is to exhibit a multiple impact law for rigid body dynamical system which meets the properties of closing the non-smooth dynamical equations and of corroborating experiments. This law is based on the impulse correlation ratio which is computed from equivalent regularized model with compliant contact. A case-study on 3-ball chain and -ball chain are delineated and results on finite dimensional system are stated.
giens.pdf (168.82 Ko) Télécharger le fichier
inria-00424301 , version 1 (14-10-2009)
Paternité
  • HAL Id : inria-00424301 , version 1
Vincent Acary, Bernard Brogliato. Toward a multiple impact law: the 3-ball chain example. 6e Colloque National en Calcul des Structures, May 2003, Giens, France. 12p. ⟨inria-00424301⟩
112 Consultations
83 Téléchargements
