Serving Embedded Content via Web Applications: Model, Design and Experimentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Embedded systems such as smart cards or sensors are now widespread, but are often closed systems, only accessed via dedicated terminals. A new trend consists in embedding Web servers in small devices, making both access and application development easier. In this paper, we propose a TCP performance model in the context of embedded Web servers, and we introduce a taxonomy of the contents possibly served by Web applications. The main idea of this paper is to adapt the communication stack behavior to application contents properties. We propose a strategies set fitting with each type of content. The model allows to evaluate the benefits of our strategies in terms of time and memory charge. By implementing a real use case on a smart card, we measure the benefits of our proposals and validate our model. Our prototype, called Smews, makes a gap with state of the art solutions both in terms of performance and memory charge.
emsoft004-duquennoy.pdf (293.33 Ko) Télécharger le fichier
inria-00424372 , version 1 (15-10-2009)
  • HAL Id : inria-00424372 , version 1
Simon Duquennoy, Gilles Grimaud, Jean-Jacques Vandewalle. Serving Embedded Content via Web Applications: Model, Design and Experimentation. Emsoft 2009, Oct 2009, Grenoble, France. ⟨inria-00424372⟩
211 Consultations
156 Téléchargements
