Sliding-Mode Formation Control for Cooperative Autonomous Mobile Robots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Industrial Electronics Année : 2008
This paper considers the control of a group of autonomous mobile robots. A coordinated control scheme based on a leader-follower approach is developed to achieve formation maneuvers. First and second order sliding mode controllers are proposed for asymptotically stabilizing the vehicles to a time-varying desired formation. The latter controller, based on the relative motion states, eliminates the need for measurement or estimation of the leader velocity. It enables formation stabilization using a vision system carried by the followers and ensures the collision avoidance from the initial time instance. Experimental investigation has been conducted using a test bench made of three nonholonomic mobile robots in order to demonstrate the effectiveness of the proposed strategy.
Automatique
TIE_Robots.pdf (734.11 Ko) Télécharger le fichier
inria-00424437 , version 1 (15-10-2009)
Michael Defoort, Thierry Floquet, Annemarie Kökösy, Wilfrid Perruquetti. Sliding-Mode Formation Control for Cooperative Autonomous Mobile Robots. IEEE Transactions on Industrial Electronics, 2008, 55 (11), pp.3944-3953. ⟨10.1109/TIE.2008.2002717⟩. ⟨inria-00424437⟩
1986 Consultations
1845 Téléchargements
