A Novel Architecture for Mobile Distributed Trie Hashing System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Scalable and Distributed Data Structures (SDDS) are a class of data structures completely dedicated to distributed environments. They allow the management of large amounts of data while maintaining steady and optimum performances. Several families of SDDS have been proposed: LH*, RP*, DRT*, CTH*. None of these SDDS deals with the mobile environment. In this paper we present a novel architecture that uses a scalable and distributed data structure to manage insert/find/range query operations for mobile clients. We describe the design and the implementation of a mobile CTH* prototype. Our experimental results prove the validity of the design choices and show interesting access performances. The capabilities of the mobile CTH* platform offer new perspectives for high performance and ubiquitous data intensive applications.
SEDE08.pdf (350.45 Ko) Télécharger le fichier
inria-00424894 , version 1 (19-10-2009)
  • HAL Id : inria-00424894 , version 1
Amel Bennaceur, Djamel Eddine Zegour, Walid Khaled Hidouci. A Novel Architecture for Mobile Distributed Trie Hashing System. Software Engineering and Data Engineering, Jun 2008, Los Angeles, California, United States. ⟨inria-00424894⟩
Collections
INRIA INRIA2
140 Consultations
137 Téléchargements
